Divide string value and show related data in Universe design
Dear Experts,
I have 2 tables
Table 1
ID Name
1 “12,18,19”
2 “7,9,11”
Table 2
ID Value
7 data7
9 data9
10 data10
11 data11
By Using Universe design i want to generate a report. In that report i want to display the Table 1 ->Record 2 i.e ID=2 & Name filed value
“7,9,11” as “data7,data9,data11”
I hope every one understand the above scenario !!!
I am assuming it can be done using “Functions” in Universe design
Please someone explain me how to handle this scenario ?
Thanks in Advance.
santhosh_03 :australia: (BOB member since 2009-07-08)
You’d need to build a database function that can be accessed by the user defined in the universe connection.
The code should, at its highest level:
Count the number of commas in the string
Contain a cursor that loops through chopping up the string and outputs the results.
This obviously depends upon your rdbms - the solution will, for example, look different in SQL Server and Oracle.
Mark,
Can you please provide the code if you have for any database.
Rakesh,
I don’t have code but in SQL Server I’d:
Declare variables for manipulating the string:
input_string, output_string, string_post, etc.
Declare a cursor to loop through the input string and write out the output string.
I’d have to test that it would work with BusinessObjects - it’s something that I’ve done a few times in ETL processes and data take-on routines though.
You can, if you are on version 3.0 and above also use a stored procedure in the universe to do this…
I’m using SQL server 2005 , So please can you provide the full function code.
Am I correct in saying that you want to turn:
“7,9,11” into “data7,data9,data11”?
Run the following in a query window (doesn’t matter which database)
declare @instring varchar(50)
declare @outstring varchar(50)
set @instring = '7,9,11'
select @outstring = 'data'+replace(@instring,',',',data')
select @outstring
The object code would simply be
'data'+replace(column_name,',',',data')
