system
1
I have 3 drill filters in my report. Year, Month, Day. The result is 2009-Nov-1.
But my requirement is to only show 2009-Nov. Iam not getting the syntax to select only two drill filters instead to 3.
Any inputs please.
Abhi
abhi234u (BOB member since 2007-02-12)
system
2
Can you elaborate how are you passing your drill filters??
Shiva
shiva.tomar (BOB member since 2007-10-05)
system
3
If you want to show just 2009-Nov, then you can use Substr() function like this.
=SubStr(DrillFilters(""),1,8)
Or you can just concatenate like this.
=Concatenate(DrillFilters([Year],DrillFilters([Month]))
Else if you want to have just only two drill filter objects, you have to work on your universe to get Year and Month together.
Jansi
(BOB member since 2008-05-12)
