Displaying a note on report depending data
I would really appreciate if I could get any help with the below situation
I have 4 different indicators on a report, the indicators can be either A, B or null, if any one of the indicators is “A”, the note should display “ABCDEF” or if all the indicators are null or display “B”, then the note should display “GHIJKLM”
How can I achieve this?
Thanks in advance
K
karan2083 (BOB member since 2010-05-06)
Hello Karan2083
WELCOME TO B :mrgreen: B
I assume you are try to do this webi? Try this:
If [X indicator object]=[A] Then “ABCDEF” ElseIf [XY indicator object]=[B] or [null] Then “GHIJKLM”
katullus :us: (BOB member since 2009-08-21)
Alerter can also be used. :idea:
