BusinessObjects Board
Display values on a bar chart
Is there any way to have values display on a bar chart (on or at the end of a bar) by default without mousing over it? Kind of like this
dstone91 (BOB member since 2015-10-29)
Welcome to B:bob:B!
Please let us know which Business Objects tool you use. WebI, DeskI, Crystal, Xcelsius, anything else? So the topic can be moved to a right folder.
Thank you.
I believe I’m using the one formerly known as Excelsius, although now the icon in the start menu just says “SAP BusinessObjects Dashboards.”
Thanks!
At least for a column chart (should be available for bar chart). Under Text tab, scroll down to Data Labels and check that box. Various options are available.
kevlray :us: (BOB member since 2010-06-23)
Perfect! Thanks!
[Moderator Note: Moved from General Discussion to Xcelsius - Crystal Dashboard Design]
Marek: Why did you move this this to Crystal Reports since dstone91 said it was Dashboard Design? Just wondering.
Hi kevlray,
The forum where I moved this topic to is not Crystal Reports, it’s Xcelsius - Crystal Dashboard Design. There is no forum just for Dashboard Designer. This current forum is for all dashboard-related issues, whether Xcelsius or Dashboard Designer is used.
Sorry, by brain got sideways I was just in the Crystal Report section and thought I still was. Please ignore my stupidity.
