Is it possible to show the value typed in by prompts in a document? It is not in the Variables list.
hans
hans
Hans asked:
Try the UserResponse function. It takes two arguments - the Data Provider and the Prompt. Hope this helps.
Marian Cooney
HBO & Company
Malvern, PA
610-296-7658 x1108
Yes. If you had a prompt with the text, say, “Enter Start Date”, you can display this on your report with the following formula:
=UserResponse(DataProvider(<obj_name>),“Enter Start Date”)
where “<obj_name>” is any object name in your query.
Erich Hurst
Compaq Computer Corporation
Hans,
Use the UserResponse Function…
Thanks!
-rm
