Display optimized sql is not pushdown when we use multiple a
Hi ,
I have source table with owner owner1. source and target table with owner2. target table.
Both are from same database ( SAP IQ). I need to use data store configurations as I need to connect multiple systems.
I have created two aliases one for source tables and another one for target tables.
I created simple data flow with one one mapping and target table without bulk load options.
If I see the display optimized sql it is showing sql statement instead of insert into statement. If I don’t use aliases and import original owner it is showing the insert into statement?
Is any impact of multiple aliases in the data store for puhsdown?
If I am using the multiple aliases, how can I achieve the puhdown?
Thanks & Regards,
Venkata Ramana Paidi.
Ramana :india: (BOB member since 2009-04-30)
