Display data from different contexts in same block in report
In one of my report I have to display data from multiple tables which are in different contexts in the universe.
I need to display data from these tables (both dimension & measures) in single block, but Business objects doesn’t allow this as the objects from different contexts are incompatible.
Is these any way I can display these objects which are part of different contexts in single block in the report.
Pankaj_G (BOB member since 2006-09-27)
Pankaj:
Welcome to BOB,
As you are new to the board we welcome you, but before posting, I would also suggest you to search in the forum, you’ll find the solutions or threads which has discussed this topic a lot… or topics on the similar issues… In addition to that, we have FAQ’s for each BO Product individually which are made sticky… go through them
Answer to your question, click the link below, which is from the BO Classic FAQ Entry:
https://bobj-board.org/t/15226/2
