Although our XI R2 license includes Crystal Reports and OLAP, I want to disable these options for certain users. I am not seeing where I can disable these applications? I would have thought I could do this in the BusinessObjects Enterprise Applications section of the CMC.
Yes, they should have been there but they are missing for some reason.
If you want to disable crystal Explorer it should be present in the Business Objects Applications section but OLAPI is not available.
Lets see if in the future Service Packs they fix this one.
Not sure if this is possible, but our contact from BO tech support suggested that we uninstall those modules on the server and that should take care of this issue. Havent tried this yet.
