i want my specific group of users should not do save and print, the file is opening in pdf, how to restrict inside the pdf to do this rights
if i give it in deski or webi it will affect for all the users, i want only to particular group, pls help
gayathrikrishna (BOB member since 2008-10-03)
hi i have the same problem.
can you say which propertie do you have changed that the users ca’t save the files?
then i can try to find out how can i do this for a group.
regards stefan
stefan zumbühl (BOB member since 2009-04-14)
create one access level (name it as disable_print_save) in this select included rights—> application—>desktop intelligence
in this select the denied option for print documents and denied option for save desktop intelligence documents
assign this acess level to the folder where you want this user rights
hope your folder is assigned with any of your exisiting groups.
otherwise create a group and users
in folders assign this secutity to the group/user created
then select this access level(disable_print_save)
