Disable design mode
I like to disable the design mode of one report to the others users who have access to this report via the categories.
How can I do it ?
I use Web Intelligence 4.3 SP 2.
Thank you for your help.
You will have to update the security for that particular report. You want to take away the Edit object permission. Don’t deny this to the Everyone group or no one will be able to edit it.
Assuming that your users have the edit permission at the parent folder, you will probably have to do this by denying a group the right to Edit object on the report itself.
Also, I removed your Webi tag as the permissions apply to Crystal Reports as well as WebI reports.
Oh okay, thank you for your quick reply.
