Most of the time, when I use dynamically scaled graphs in sections, all graphs end up with the same scale, fitting the max value from the section that has the highest data value. In some reports, the scale changes from section to section.
Can anyone explain what causes the report to behave in these different ways? What do I need to watch out for when building the report?
Yes, in many cases, the max value is very different between sections. For example, suitable scale can be 0 to 10 in the first section, 0 to 2000 in the second section and 0 to 50 in the third section. My reports sometimes have several hundred sections. It would be so nice if the scale changed dynamically depending on the range of the data in each section.
The difference is the type of chart.
When you set the type to stacked column chart (even though there is only one series to show)
the chart will be scaled for each section separately.
