I am using the same configuration as Duke, except that I do not have the 3rd party ODBC SQL Server driver…
Duke, did you get any answer/explanation from BO Tech support?
Toan
Viet-Toan Nguyen
Schlumberger Dowell
SHPC-D DSC/MIS Software
CSNE Engineer - Ecole Centrale Paris
Tel: (281) 285-7814
Fax: (281) 285-4706
Sent: Friday, July 24, 1998 2:41 PM
I am using the latest ODBC SQL server driver- 2.65.0252. I had the same
problem using BusObj 4.1, and now with 4.1.2a. The database is on a NT
server, SQL Server is 6.5. I would test a query and view the results in the
data manager window. I can see there the date, time and rows information.
I then close BusObj, open Supervisor, and change the mode in the connection.
I then re-start BusObj, open the previous saved report go into data manager,
and do a re-fresh. With Async, I get the wrong results (verified with another application). In sync- I always get the correct results, or using a
3rd party ODBC SQL Server driver I also get the correct results.
I hope you are not getting wrong results since the switch! Let me know what
you find out!
Sent: Friday, July 24, 1998 2:22 PM
Toan and Duke,
what are your configurations? BusinessObjects version, database type
and version? Also , is this problem easily repeatable? The reason I am
asking is because I recently switched our connections to asynchronous, for
the reason you mentioned about starting other applications. Also running
in asynchronous mode allows you to cancel the query at any point not just
in the fetch phase. I would like to test this on our site to see if it
restricted to a particular database or if it is more generic. Thanks
Glenn Fredericks
Data Warehouse Specialist
glenn_fredericks@aal.org
(920) 730-4700 x4236 or 1-800 CALL AAL
Aid Association for Lutherans
4321 N. Ballard Road
Appleton, WI 54919-0001
Visit our Web site at www.aal.org or e-mail us at aalmail@aal.org
AAL… Financial services. Lutheran heritage. A powerful combination.
For old 3.1 info:
Penn: Page not found
Search: Mail to listserv@listserv.aol.com, ‘search a_phrase in BUSOB-L’
For old 3.1 info:
