Different Level data in 1 Column
Hi Gurus,
I’ve a scenario and i want to do it in Webi Report.
The scenario is:
I’ve 3 different levels of Account no’s.
I’ve to create a Column where all the 3 different levels has to appear in one column as per conditions. The conditions are,
  1. If there is no subtotal in the Row then it is Level 3 Account no.
  2. If there is Level 2 Subtotal in the row then the account no. is level 2 account no.
  3. If there is level 1 Subtotal in the row then the account no. is Level 1 account no.
Can any one please suggest me a way?? :hb:
If you need more information, please let me know.
Thanks a ton in advance.
Ravi Kanth
ravikanthbn :singapore: (BOB member since 2009-04-16)
Use IF Else funtion…
Or let us know more details…
amitrathi1234 :india: (BOB member since 2007-10-15)
If else function can work but i need to know that the data in the row is related to Level 3 or Level 2 or level 1 account data. How could i know this?
Can you please suggest me a way?
Please.
In your report there is any flag or any dimension objects by which you can know?
