Difference between two Deski rights
Hi guys
can you tell me what Deski\Infoview functionality each of the following rights affect:
Desktop Intelligence Document Interaction
Desktop Intelligence Report Interaction
Thanks guys.
JJ
jane123 :it: (BOB member since 2006-02-22)
Have a look at this document (http://www.sdn.sap.com/irj/boc/index?rid=/library/uuid/9084aebf-c01d-2b10-3aa8-f67c159b90b7&overridelayout=true) which explains not only these two rights but all the other ones too.
Orange :netherlands: (BOB member since 2006-09-18)
The names are misleading, that’s for sure, but …
Desktop Intelligence Document Interaction controls whether or not you can add / delete / rename report tabs (contents of the document).
Desktop Intelligence Report Interaction controls whether you can add / change / delete the report contents (tables, charts, cells on the surface of the report). Easy to test, since without this right a user cannot select anything on the report surface.
