difference between mail_to() and smtp_to() functions.
difference between mail_to() and smtp_to() functions.can you please tell me pre-requisites to use those functions in data sevices script?
please reply ASAP. :hb: :reallymad:
bashabobj (BOB member since 2013-04-16)
Here’s what’s been said previously:-
Nemesis :australia: (BOB member since 2004-06-09)
Thank you very much Nemesis. :smiley:
You will find this also in your Technical Manuals which is installed with your Designer client as either a PDF or Windows Help File, depending on the version of Data Services you are using.
From the DS 4.1 Technical Manuals, the Reference Guide section, I quote page 1719:
And page 1771:
This is not a polite RTFM but the Technical Manuals (and in particular the Reference Guide) is often overlooked as a source of answers. Mostly because most documentation supplied by any vendor is not very useful or easy to understand.
However the Data Services Technical Manual is a very well written document (or rather a book combining several documents including the excellent Reference Guide) and provides heaps of great information. I believe that over half the topics in the Data Integrator forum would not have been required if people had realized the answer could be found in the Technical Manual.
ErikR :new_zealand: (BOB member since 2007-01-10)
Full agree! There is a wealth of information in the standard documentation… I suppose BODS is one of the better documented tools on the market…
