Difference Between BW Extractors and ECC Extractors
Hello,
Can anyone tell me is there a way to use the BW Extractors and extract the data in BODS 4.0. I have worked on ECC Extractors.
I have created a BW Data source Connection but not found the extractors in it.?
Can anyone share their experience on BW extractors in BODS.
Bharat
048886 (BOB member since 2013-11-11)
Do you mean extract from BW ?
Leigh Kennedy :australia: (BOB member since 2012-01-17)
Yes, is there a way to extract data from BW using the BW Extractors?
Bharat
Do you mean the BI Content Extractors?
If so yes. BW Extractors are really the extractors sitting on the ECC system consumed by BW.
You need to activate the extractors in ECC and pull them via ECC and not from the BW system datastore.
Also let us know which version of DS you use.
Hello Ganesh,
Thanks for the reply. we are using Data Services 4.0 SP3 version.
Bharat
Okay so extractors are supported. And what is your issue exactly?
