Why do we need to create Detail Objects ? We could have easily created Dimension objects…What is the purpose of having Detail Objects ?
Developer_Designer (BOB member since 2009-08-09)
In order to avoid incompatibility issues. Check this topic for one such scenario.
Jansi (BOB member since 2008-05-12)
Jansi,
Thanks for your response. I read your given link. But it does not answer my question. Let’s say I create a dimension object ‘Customer Name’ at the universe and a detail object ‘Customer Phone Number’. Why do I need to make it as a Detail object instead of Dimension ? Your given link discusses about the detail objects which are only created at the report level ?
Can you please give me an example so that I can understand more clearly ?
I appreciate your time.
Please read the designer guide.
I have read the Designer guide once again. I still could not figure it out. The guide says ‘HOW’…but it never says ‘WHY’.
Thanks Jansi. But it still did not serve my purpose. So far the informations I got about Detail Objects are:
But nobody is telling, why do we need to create detail object ? What is the main purpose of it ?
It’s simply a way to organize your objects. You don’t need to have any Detail objects if you don’t want to. One advantage is that it reduces the number of objects that appear in a class so it isn’t so intimidating for the users if you have a universe with a very large number of objects.
tmarion (BOB member since 2002-08-20)
You do not have to create detail objects at all. However, the “philosophy” of universe design says you should. Any item that is supporting information (phone number in your example) should become a detail. If you leave it as a dimension it doesn’t break your universe. But…
I have seen plenty of universes where no detail objects were created and they work fine. But they are not true to the “philosophy” of universe design.
