Deski schedule output as structure instead of results
While schduling few Deski reports they delivered as structure format instead of results, our environment is BO XI 3.1 SP2 Solarix and these reports were migrated from BO 6.5 environment. Did any one came across similar issues?
Nirmal
nimu1979 :india: (BOB member since 2008-08-04)
Check if the reports are saved and exported (to the repository) in the structure format.
No, the reports were exported with results only, if i manually refresh the reports it displays the results.
