DeskI, Citrix and Active Directory
There is a problem using AD authentication for DeskI in Citrix environment. (XIr2 - version 11.5.8.826)
The situation is following
  • AD authentication is activated and working (groups mapping done)
    for DeskI installed locally
  • in Citrix, Enterprise authentication is working but not AD authentication
    I receive then message
[repo_proxy 13] SessionFacade::openSessionLogon with user info has failed(Security plugin error: An error has occurred in the plugin, but the plugin is unable to return a detailed error message.(hr=#0x80042a01)
After searching through the posts, I tried to re-activate secWinAD.dll
without success.
Any ideas ?
Thx
N.
Nicolas Debaveye :japan: (BOB member since 2008-07-31)
Got it!
I had to resintall the full client package instead of selecting DesktopIntelligence only in Enterprise package (then dll was missing)…
