system
August 27, 2009, 6:09am
1
hai all…
I started CMS , and then when i clicked on the designer, it asks for the login, after entering the login details, it the designer page suddenly falshes for a second and disappears…
what should i do, i tried for it from C:\pragra…\Win32_x86\designer.exe to open it… but its also not working… plzzz help me in this…
Thank you…
sudheer.k27 (BOB member since 2009-08-27)
system
August 27, 2009, 6:11am
2
Welcome to B:bob:B !
Moderator Note: I don’t think it is related to DI, so I’m moving it to Universe Designer.
Jansi (BOB member since 2008-05-12)
system
August 27, 2009, 6:16am
3
thank you jhansi…
system
August 27, 2009, 6:24am
4
Please help me some one soon … do i need to re-install whole the BOXIR2 or is there any solution… ?
system
August 27, 2009, 6:25am
5
Hi.
Are you take a look to Windows Event Viewer?
Maybe it say something about why the designer fails.
Good luck!
Jaimepe (BOB member since 2006-12-10)
system
August 27, 2009, 6:41am
6
Thanks jaimepe for ur reply…
I checked in the events again…
It is saying that “transport error.Comminication Failure”
system
August 27, 2009, 6:49am
7
Its strange.
Inside the event viewer->Application no said nothing?
Could you take a look in …Business Objects\BusinessObjects Enterprise 12.0\win32_x86
sometimes BO writes log inside…
Good luck!
system
August 27, 2009, 6:58am
8
yeah… It is saying that “Transport error.Communication Failure”…
system
August 27, 2009, 7:01am
9
Take a look to:
We’re seeing the same error, in both Designer and in Desktop Intelligence. These tools work Ok on the server, but from no other PC. We tried PCs in the same domain, and in different domains as well.
We consistently get this error in the Desktop Intelligence login process on the client PC: SessionFacade::openSessionLogon with user info has failed(Transport error: Communication failure.
(hr=#0x80042a01)
And in the client PC’s Windows Event log, we get this: Event ID - 34700, Source - Busine…
Maybe helps you…
system
August 27, 2009, 7:47am
10
system
August 27, 2009, 9:12am
11
Had a case of this last week!
we deleted the LSI file in C:\Documents and Settings<USERNAME>\Application Data\Business Objects\Business Objects 12.0\lsi and it started working.
Sushir Patel (BOB member since 2006-04-19)
system
August 27, 2009, 10:21am
12
Hai HRS, Thank u soo much for your concern… But Its Not Working In my Case…
system
October 19, 2011, 11:02am
13
[quote:bd4ec360ad=“sudheer.k27”]Hai HRS, Thank u soo much for your concern… But Its Not Working In my Case…
[/quote]
I know this is a old post, but did you get this to work, and how?
We have upgraded to XI3.1 SP4 in testenvironment, and one issue is just like yours. Designer screen flashes for a second, and then nothing.
If anyone have inputs, i’m all ears!
/Björn
Bjorn (BOB member since 2006-02-10)
