DESIGNER CALCULATED MEASURE FOR REVENUE BY DOCUMENT TYPE
Hello friends. I am trying to calculate the custom measure that calculate the revenue where document type = KA
can u please help me with the code that can be used in oracle data base to implement using the revenue measure and document type object to have revenue by document type = KA
tHANKS
SONIYA
soniyakaren (BOB member since 2009-07-21)
Here you go
 CASE WHEN TNAME.document_type = 'KA' THEN TNAME.REVENUE ELSE 0 END
If it’s a measure then I would wrap the above formula with SUM() function:
SUM (CASE WHEN TNAME.document_type = 'KA' THEN TNAME.REVENUE ELSE 0 END )
