BusinessObjects Board
Design Studio Images location?
I am using design studio v1.3
When I use images in the application and the path of the images changes the images are not loading (ofcourse)
Example:
Public Folder\Dashboard\001-test
This path is not dynamic, when i rename or change the folder strucure all image paths must be edited. Is there a way to make this more dynamic?
Using the path image\logo.jpg only is not working (how I would have done it in HTML website)
thoraxx (BOB member since 2012-05-03)
no solution for this?
If the Image Location or Image file Name changes in the BI Launchpad you need to change the Path in your application manually.
This is the only way of automatically changing the path in Design Studio Application if the Image path changes.
Ishani
Ishani :india: (BOB member since 2015-12-16)
