Design Studio Charts
Does anyone know if we are able to create a chart in Design Studio that would allow the user to drag/drop or select what components they want to see in the chart? The user is needing to customize their chart based on their data selection. I’m not even sure if this is possible… any help is appreciated.
Thanks!
switchblade79 :us: (BOB member since 2017-03-24)
Yes. It’s called the Chat_Type_Picker. You would have to script to make it work. But do able. Here some info on it.
https://help.sap.com/doc/4f58d91f03e441b68d3187e94be27df2/2.0.2.0/en-US/5d5f9ec7c15c4d5bbfe89ce291cffbf6.html
katullus :us: (BOB member since 2009-08-21)
Is this Lumira 2.1 Designer (i.e. the latest version of DS). Theres a component in there for this, you assign a dataset and you have Lumira style capability for the user to change dimensions and measures and also chart types. Its actually quite nice!
Thank you!
