Design Studio 1.3 Installation - JRE 1.6/7 not found error
Hi Gurus,
I am facing an issue during the SAP Design Studio 1.3 installation. I am getting ‘Oracle Java runtime environment 1.6/7 could not be found’ error. I checked my java version and it is JRE 7. Also based on other forum discussion, I checked the JAVA_HOME and PATh environment variable values as C:\Program Files (x86)\Java\jre7 and C:\Program Files (x86)\Java\jre7\bin respectively. Still I am getting the JRE 1.6/7 not found error :roll_eyes: .
Could you anyone help me in sorting out this issue :(.
My machine is Windows 7 64 Bit.
Aashik Sujaudeen
AashikSujaudeen :india: (BOB member since 2015-07-08)
Now I am able to install Design Studio 1.3 :wave: .
The issue was due to JRE 1.7 64 bit version.
With respect to the pre-requisites given in the PDF https://websmp204.sap-ag.de/~sapidb/011000358700000211262014E, the JRE version should be JRE1.6/7 32 Bit irrespective your system/machine is 32 bit or 64 bit.
Also I set up the environment variables JAVA_HOME and PATH as the JRE installed location (C:\Program Files (x86)\Java\jre7\bin)
JAVA_HOME
Aashik Sujaudeen
Please, why are you installing a really outdated version of DesingStudio in the first place? Current version is 1.5.
Hi Andreas,
Yeah the latest version is 1.5. But in my Organization, we are using Design Studio 1.3 version right now. We are planning to switch to Design Studio 1.5 in one month.
Aashik Sujaudeen
