BusinessObjects Board
Design Studio 1.2 with Oracle UNX
Hello,
Does anybody know if Design Studio 1.2 supports UNX universes on top of Oracle databases? Everything I see in the SAP documentation says it only supports relational if SQL Server or Sybase IQ is used. It’s a bit painful wading through all the links and docs on the support portal though.
If not supported, do you know when it might be?
Shelley
cooks (BOB member since 2004-10-01)
Not officially supported, but should work. Should be officially supported hopefully with upcoming 1.3 or so.
