BusinessObjects Board
Deselect slected row on Scorecard in Xcelsius
I am using Scorecard in my multi tab based dashboard, when I click on any row (Rows are selectable) I get pop up and I can close using push button.
When I move from that tab to other tab and go back to scorecard tab then pop up come without any click. I was assuming that once I clear selected value of scorecard using push button then there should not be any selected row.
Any workaround?
bo_user123 :uk: (BOB member since 2010-09-22)
Hey there…
even I too have this issue,and i spoke to many Pro-Developers about it. But unfortunately they were not able to figure out any work around.
The only thing we can do is reset the whole dashboard everytime.
Please share if you find any solution.
RAVI
rt7756 (BOB member since 2011-05-04)
I believe the first column is already selected in Scorecard, try keeping it No Selection and see.
Zaif
zaif235 :us: (BOB member since 2010-06-15)
Nothing is selected by default (No selection(none)), I am able to put null in selected row and it work fine when I am in score card tab. when I move away fro that tab and come back to it then last selected value is automatically get selected and due to that i get a pop up.
Thanks In Advance
maybe this little example may help you. I hope i understand you right.
best regards
scorecard_tab_close.zip (11.0 KB)
Despicatus :switzerland: (BOB member since 2010-05-07)
hope following links will help you
1.)
2.)
http://www.agiledss.com/en/blog/xcelcius-how-solve-scorecard-interactivity-issues.html
Karthik
mkarthik5949 (BOB member since 2014-11-25)
