delete document from supervisor
Hi ,
I have been set as supervisor-deisgner under root directory. My General supervisor enabled the delete document option under supervisor configuration.
If i login to supervisor, i don’t see any delete document under tools.
But i see delete universe which has been set as inherit .
How can i get that access?
Let me know.
Thanks in advance.
psk (BOB member since 2004-08-04)
Are you a member of any other group? If “Delete Document” is hidden or disabled for you in any other group, then you will not be able to delete documents in any group.
To understand what Michael is saying, read this entry from our Supervisor FAQ, the sticky at the top of this Supervisor forum.
