How can we change the webi Default page margins.(Which are default 76px) on BO R3.
p
kusamp (BOB member since 2008-09-25)
p
Modify the PageLayout properties.
-srujana
srujanaj (BOB member since 2010-02-10)
hi srajanaj,
could you clarify your answer please?
where can we set the page margins?
thanks
pijo
pijo (BOB member since 2009-08-13)
To be very specific, can a report developer modify his or her own default page setup? (as opposed to a global page setup that is pushed out to all developers based on ahow admin setup page defaults)
If the answer for the user is yes, then how does the user do this? If the answer is no, then where does the admin set the defaults? Can admin set up different templates that developers can choose from?
LaurenBOXI (BOB member since 2009-09-15)
You can change some settings to the defaultconfig.xml file, but only things like table layout and default page layout like A4, A5, portrait, landscape etc… You CANNOT change the page margins.
You can find the defaultconfig.xml file in:
BOXIR2:\Program Files\BusinessObjects\Common\3.5\Java\WebiApplet\AppletConfig
BOXI 3.1:\Program Files\BusinessObjects\Common\4.0\Java\lib
There is an enhancement request logged, search for ADAPT01258598 on the sap-site
