Dealing with a Single Quote in a DB2 CASE Statement
I’ve had a search through the board and can’t find this question so I hope I’m not going over old ground.
I have the following CASE statement:
 CASE ( PDDB2DB.PWRSCUD.USER_DATA_2 )
       WHEN '2A        ' THEN 'CHARLES CAPP'
       WHEN '2BA       ' THEN 'MARK O'NEILL'
       WHEN '4AD       ' THEN 'GEORGE PAGE'
ELSE '          ' END
The single quote in O’Neill has caused problems.
I’ve tried rewriting it the problem line as
WHEN '2BA       ' THEN 'MARK O'!!CHAR(39)!!'NEILL'
to create a single quote in the result from the ASCII code. Unfortunately it returns the result ‘MARK O39 NEILL’.
Can any one help?
I’m using Business Objects 5.1.8 and IBM DB2 V7 Rel 1.
Many thanks
Jude
curtins4u (BOB member since 2007-07-25)
jude,
I’m not sure but shouldn’t you use the concatenate-characters || in stead of !!
Maybe it’s just a typo :stuck_out_tongue:
Hope this helps,
Johan
JdVries :netherlands: (BOB member since 2006-02-06)
Johan, thanks for quick answers.
I gave it a try, but unfortunately DB2 treats !! and || as the same thing.
Thank you anyway.
Jude
Have a look at this post
Jude,
To bad…
Then probably the CHAR-function is not correct.
Maybe there is something like a CHR-function…
As you’ve noticed, I’m not a DB2-specialist.
Johan
haider, Johan,
thanks for the responses but it’s still not working at the moment.
These are some other variations in the CASE statement I’ve tried:
WHEN '2BA       ' THEN 'MARK O''!!'NEILL'
WHEN '2BA       ' THEN 'MARK O'' 'NEILL'
WHEN '2BA       ' THEN 'MARK O" 'NEILL'
The last two were my attempt to replicate the other topic that haider referred me to.
I’ve looked for alternatives to using CHAR() but can’t find any.
Many thanks
Jude
jude,
A bit googling and altavistaing gave me this site:
http://publib.boulder.ibm.com/infocenter/db2luw/v8/index.jsp?topic=/com.ibm.db2.udb.doc/admin
Search here for ‘chr’…
Hope this helps,
Johan
Johan, unfortunately that seems to be a feature of DB2 V8
Jude
Ensure that its not double quotes after O but two single quotes and there is no single quote before NEILL.
Cheers
haider, I tried it with both " and ‘’ without any joy.
I’ve tried this directly in DB2 QMF and have the same issue, so I assume that it’s a DB2 issue rather than Business Objects.
I’’ try some DB2/SQL forums to see if I can find the answer.
Thank you to both of you for your time.
Jude
