DCOM ERRORS
Our server tech team has made some rehistry changes on the servers running webi.After that i started seeing loads of DCOM error in event viewer.Iwas really concerned about those DCOM error as they may destabilised webi.
Could you please advice-Here is the error message-
DCOM got error "The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. " attempting to start the service BITS with arguments “” in order to run the server:
rao (BOB member since 2003-06-02)
I don’t know service BITS (so if DCOM is not able to start it, may be you will noit have problems with webi)
Anyway, my life was getting better when I was able to manage the server & application, stricly following BO recomendations: no other applications on the server, full adherence to PAR, no “customizations” to gain perfomances.
More or less: leave as it is after installation
Alex
alex :it: (BOB member since 2002-08-23)
Unless you have specific evidence of these messages destabilising WebI, don’t worry.
