DBIF_RSQL_SQL_ERROR
I am running a job which was running for the past year without any issues.
Today morning it failed with the above mentioned error listed as…
The SAP job was canceled for host <>, job name <ZSales_SAP_GL 03/05/11 17:04:4>, job count <17041501>, job log from SAP
<10/24/2013, 09:47:13, Job started
10/24/2013, 09:47:13, Step 001 started (program ZW40418051, variant &0000000000000, user ID CRYSTAL)
10/24/2013, 10:47:33, Internal session terminated with runtime error DBIF_RSQL_SQL_ERROR (see ST22)
10/24/2013, 10:47:33, Job cancelled
10/24/2013, 10:47:34, Function call <raise_exception (Aborting) > failed, due to error <50316>
Aborting
This is a first for me; any ideas out there !?
Aborting
BOETL2012 (BOB member since 2012-08-27)
If you will have access to ST22, then please check the dump in there. It almosts sounds for me that the ABAP SQL ran out of disk space
BASIS should help you with this.
Please re-run the job.
Raghu_BODS (BOB member since 2013-09-16)
