I am trying to define a predefined filter.But my Sql is not working(syntax error).
My requirement is to get the data or prior month when the input(prompted to the user) is a time span.
For eg User could input time span = “Month Ending 01 Jan 2001”,“Month Endind 02 Feb 2004” etc.If it is jan then i need like dec of prior year eg for “Month Ending 01 Jan 2001” it should return “Month Ending 12 Dec 2000”.Input is of character data type.
My sql goes like this PS_Z_PERIOD.Z_PERIOD_SPAN=CASE WHEN substr (@variable( ‘Time Span:’),14,2)=‘01’ THEN SUBSTR(@Variable(‘Time Span:’),1,13) || "12 Dec " || CHAR(INTEGER(SUBSTR(@Variable(‘Time Span:’),LENGTH(@Variable(‘Time Span:’)) - 3, 4)) - 1) ELSE SUBSTR(@Variable(‘Time Span:’),1,13) ||CHAR(INTEGER(SUBSTR(@Variable(‘Time Span:’),14,2)-1) || " " || substr ((MONTHNAME((DATE(‘9999’ || substr (@variable( ‘Time Span:’),14,2) || ‘01’)- 1 MONTH))),1,3) || substr (@variable( ‘Time Span:’),(length (@variable(‘Time Span:’))-3),4 ) .
There is a problem with the last line of code (length (@variable(‘Time Span:’))-3),4 ).error shows unexpected token")" , expected token “)”.
rocky (BOB member since 2005-03-29)
