DB2 in Mainframe
I was told to work on a BO migration from 4.1.3 to 5i where BO repository is in DB2 ver.7 in Mainframe .Any body work in this environment ?How much is the environment different from DB2 in Unix environment ?Is there any documents available ?
Hari
haribalakrishnan (BOB member since 2003-04-10)
used it for years till just last month when we went to UDB.
As far as the BO side of the repository, there is no difference between OS/390 DB2 and UDB/DB2. You can use the DB2 Connect driver for both if you like.; that should make the conversion easier.
scott copeland (BOB member since 2002-08-15)
agreed … there’s some db2.sql scripts that you’ll need to modify to upgrade your repository … there’s also a pretty good how-to doc on the tech support website that you can use to put together a task-list/gantt-chart
Chris Pohl :us: (BOB member since 2002-06-18)
