system
1
I am using Business Objects report to calculate days between for a date in database with time stamp and current date.
For example :-
7/16/09 15:54:00-------------- 8/12/09 13:02:35(current date) is 27 days
The same when did in crystal reports using print date
7/16/09 15:54:00-------------- 8/12/09 13:02:35(print date) gives 26days
How can i calculate days between correctly in BO reports so that it also takes time stamp into consideration.
–h
hourigan (BOB member since 2007-04-06)
system
2
Check this old topic if it helps:
There is described a way how to get the difference between 2 dates down to seconds level.
Marek Chladny
(BOB member since 2003-11-27)
