datetime2 to datetime out-of-range value error
I am getting the following error while running Fixed Assets rapid mart for SAP application.
Both input and output schema for fields have compatible datetime data types
20128 22404 DBS-07040 The conversion of a datetime2 data type to a datetime data type resulted in an out-of-range value.
its_ranjan (BOB member since 2011-02-16)
Any resolution to this error? I am getting the same error when I converted the job from ver 3.2 to 4.1. I have source as Oracle and target as SQL server 2008. I also tried to_char around all my datetime columns. It still fails with the same error.
Help will be appreciated.
Matt
Mattdos11 (BOB member since 2006-02-07)
