I am breaking my head on the wall to find out what is the wrong with the datetime columns. Here is the Scenario:
I am using ‘Date’ functions for all the date type columns, because, to avoid time stamp.
I am using all the date objects in the (result objects) report without any problem.
I tried to create a condition based on the date range and ran the report, I got the error message as follows
"The string representation of a datetime value is out of range. "
I tried to select the values from LOV, it showed date&time eventhough I used Date function on that object and changed the format in the universe.
I changed the format ‘mm/dd/yyyy’ as in database on that object in the universe.
I tried all the possibilities, but end in vain.
Please folks, help me out on this issue. What are the other possibilities to solve this problem? Any BO Driver problem?
Ravi.
______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
Which db2 version you are using ? Db2/nt or db2/mvs and V5.2.3 or V6.1
Hi DB2 Folks,
