date format issues with extractors
I am having a problem with passing date formats to sap extractors. I think this is a bug, but may be wrong.
I have two extractors both of which have a DATETO column.
Both on them contain in the queries where clause
DATETO = ‘9999-12-31’
In the first case this works. In the second case it doesn’t. I can verify the issue is related to date formatting, as if I replace the statement with
year(DATETO) = 9999
they both work !
Firstly, is there an unambiguous string I can use here ? My assumption is for some reason, even though the first one converts as YYYY-MM-DD, the second one doesn’t.
Secondly, if I use to_date to explicitly convert, won’t this prevent pushdown ? In some of my extractors we rely on the dates to limit volumes. Does it make a difference if were to do this in the start of my job and set a variable
i.e. $SAP_ENDOFTIME = to_date(‘9999-12-31’, ‘YYYY-MM-DD’)
vs in the where clause ?
Thanks for your help !
Leigh Kennedy :australia: (BOB member since 2012-01-17)
Version of BODS? One of the most recent fixes fixed some inconsistencies around dates for the extractors.
Yes. Its DS4 SP3. Issues occurs in both SP3 base and SP3 Patch 1
I started documenting that in the Wiki but had a few questions myself.
As it sounds you are using an Extractor in query mode and you add a where clause there, make sure it is a >= and <= condition and the global variable used in a date datatype.
Yes, I’m using the extractors in query mode.
In this case as I only want correct records, I am using = rather than a range. And it is now working by using a global variable of type date, but it used to work fine until SP3 with the strings.
