we got a rather strange issue after migrating to SQL-Server-2012.
When loading date-columns, we are given the following error: “error message for operation : <[Microsoft][ODBC SQL Server Driver]Optional feature not implemented>”
This happens, when we try to
- load from Flatfile [FFA] (reads column als DATE, YYYYMMDD)
- via BODS-Query (handles column as DATETIME)
- to target-table [TTA] (DATE-Column, non-bulk-load)
When we swith to bulk-load, everything seems to work well and the data is loaded quite fine.
If we change the above scenario to the following:
- via BODS-Query (handles column as DATE)
We get another error: “Datetime field overflow”
Regardless, whether we bulk-load or do a normal load.
While we only load DATES with no time-portion, I tried
TO_DATE( TO_CHAR( … )) as well as
SUBSTR( … )
but to no avail.
I also tried to alter the target-columns from DATE to DATETIME and to DATETIME2 but nothing seems to work.
We are working with:
BO EDGE 4.0 (14.2.5.000),
SQL-Server 2012 (11.0.2100.60 (X64))
ODBC Driver 13 for SQL Server
Can anybody advise me on this problem?
Any help is greatly appreciated!
Scattered (BOB member since 2011-01-07)
