I am trying to create a schedule for running a job every 30 minutes from 7 am to 7 pm EST. I did read some forums which tells me that I should set Repeat (Minuites) parameter. I do not see this parameter on job scheduling page. I only see Duration paramter. Could you please tell me where to find this parameter?
sallam (BOB member since 2013-05-22)
[Moderator Note: Moved from General Discussion to Data Integrator -> DI: Designer and Job Design]
And welcome to B:bob:B!
Marek Chladny
(BOB member since 2003-11-27)
And we are talking about the BODS scheduler via de administration console?
I see in every job the following 2 parameters, regardless of the settings in the schedule:
Duration (minutes):
Repeat interval (minutes):
Duration needs to be set to 12 hours I guess and repeat interval to 30 minutes.
Johannes Vink
(BOB member since 2012-03-20)
