Data Services Ignoring Bypass setting?
In one particular environment at a client of ours, Data Services ignores (or rather FAILS to ignore) work flows and data flows set to BYPASS.
The ByPass substitution parameter has been correctly set. Work flows are marked as Bypass. The job is save and executed… and Data Services happily executes the work flows that should have been bypassed!
This is with DS 4.2 SP10.
In other environments it works just fine so I’m a bit puzzled here. Has anyone seen this behaviour before?
ErikR :new_zealand: (BOB member since 2007-01-10)
I know it ignores the bypass setting in Debug. (along with a great many other things that are wonky in debug) :crazy_face:
jlynn73 :us: (BOB member since 2009-10-27)
I’m definitely not using Debug mode :slight_smile: I see that there’s a Patch 1 release for SP10… I may have to have a look in the release notes.
