Data Services and SIEBEL
Dear All,
I’m looking for all documents related to Data Services and
Siebel(connection, extraction, Best Practices, ecc…), where I can find
these information.
Does exist Data Services standard extractor that get data directly
from Siebel ?
Best Regards,
ZAV
:wave: :wave: :wave:
zavatta_fighter (BOB member since 2005-05-10)
We get data from Seibel via an odbc connection to the database. IT works fine for us.
Leigh Kennedy :australia: (BOB member since 2012-01-17)
Thanks Leigh Kennedy
ZAV
At one point DS had a Siebel adapter. Maybe it still does.
This let you browse the Siebel object metadata. But at the end of the day, it still communicated at the database level, not via the Siebel API.
If you’re writing data into Siebel, you’ll need to use the EIM tables.
ZAV
