Hi. everyone.
we use to data integrator 11.5, now we upgrade to Data Service 4.1
No problem, except SAP R/3 abap data extraction…
i install R/3 function module(like R900231.R63) and create user, and make a role … etc
i test on development sap server, qa sap server … it was worked.
so we applied real operation server.
but i found like this error message( we use ftp transportation method - but rfc method same )
RFC CallReceive error <Function /BODS/RFC_ABAP_INSTALL_AND_RUN: RFC_ABAP_MESSAGE, Changes to Repository objects are not permitted in this client)- Changes to Repository objects are not permitted in this client
i was googling and searching
if i use TCODE SCC4 “Client-Independent Object Changes” option change to “Changes to Repository and cross-client Customizing allowed” - it’s work.
but, we don’t change this option. reason for audit.
actually we don’t have basis. so i don’t confirm sap user configuration and role authorization. ( gave SAP_ALL role same error occurs…)
how can i resolve this issue? how can i connect to Closed Sap application data?
i have to /BODS/BODS re-configuration? i just upload file(function module) and i didn’t anything.
i tried data service option “Generate and Execute” to change “Execute Preloaded” . but it makes like error message -
RFC CallReceive error <Function /BODS/JOB_RUN: RFC_ABAP_EXCEPTION-(Exception_Key: ABAP_PROGRAM_DOES_NOT_EXIST, No appropriate entry found in table ADRT)
i saw in scn or support portal document about first error message, but i can’t found related document for second error message.
I just 3 day for live. please help me.
moonistar (BOB member since 2013-11-28)
