Data Quality BO XI3.1
We have enterprise BoXI3.1 license. Can any one please let me know does it include Data quality as well?
If yes, how can I install it, I have installed BO XI 3.1 but not seeing data quality any where?
If no and we need to get license separately, can any one please let me know the installation instructions. Can we integrate it with our existing BO installation.
Thanks in advance.
Rodger (BOB member since 2007-09-16)
If you had Data Integrator alone in the past without any Data Quality products, that’s what you get - Data Integrator (Services) XI 3.1. To get the DQ options up and running you would need to download the corresponding DQ directory and add a license key you get when you purchase the option.
For DQ customers it is similar, they get the same product but all advanced DI transforms disabled, just the DQ transforms enabled. If they like to see DI transformations they need to purchase the corresponding license key for the DI part.
Thanks, for the reply. Can you please let me know the location where I can info some documentation on Data quality, userguide, installation docu....getting started.
Thanks, once again.
Hi Rodger,
you can find documentation on Data Servies XI 3.1 on the SAP Help Portal. The Data Services documentation includes information about the Data Quality components as well.
Niels
nweigel :de: (BOB member since 2008-11-05)
Here is the link
http://help.sap.com/businessobject/product_guides/
gssharma :india: (BOB member since 2006-10-30)
