Data provider yielding no data to fetch return msg
In several reports I have several data providers that are conditional upon other data providers. There are instances where a data provider may not have data to return, and I would like to know if there is a way to prohibit the No Data to fetch msg.
Thanks in advance,
Mike Byrd
MByrd (BOB member since 2004-08-23)
Please see this FAQ entry.
Also do a search here on BOB for “prevent no data to fetch” or “suppress no data to fetch” (without quotes), and you will find many past discussions.
Note: the search engine ignores words less than three characters, so “suppress data fetch” or “prevent data fetch” will return the same thing.
