I may be missing something obvious here, but how/when do you prevent the data-provider name appearing with the object name in a document using multiple data-providers? eg.
Report 1 has 3 objects - object1, object2, object3 Report 2 has 3 objects - object4,object5, object3
Note that object3 is in both reports.
If the two reports are generated from 2 different data-providers (whether or not from different universes) in a single document, the data provider name appears in the =NameOf formula for the column heading for object3.
So,
Report 1 looks like
Object1 | Object2 | Object3 (query 1 with universename)
