I wanted to know if there was any limitation for using flat files in rich client. If so how many tuples or records does it support?
Thanks in advance.
mrteja86 (BOB member since 2011-03-08)
Thanks in advance.
Hi mrteja86,
what are you trying to achieve here?
swap_l (BOB member since 2009-04-09)
Hi swap_l,
We are trying to get data from a csv file that has more than a 1.5 million rows. This might increase and so we were wondering if there was any limit for this. the file has 270 columns and so it would not fit into a .xls file.
Is there any limit for flat file format as a data souce?
