I have a line graph with X and Y axis. I have also inserted data labels on the line graph to show what every data point value on the graph represents.
But these data labels appear exactly over the data points on the line graph. This makes little unreadable from user perspective.
I tried to use the Format Data Labels options. But on the Alignment tab Horizontal and Vertical options are disabled and only the Orientation options is enabled.
Can someone let me know if there is any way I can place the data label a little away from my line graph? Is there anyway to control the alignment of the data labels.
dinarra (BOB member since 2013-09-27)
