I am using BO 4.0 and Dashboard design. I have a monthly crosstab report which i am using to build a scorecard in dashboard.
My data is growing from left to right. example
Jan Feb March
North 3 4 5
South 3 6 5
so If i make a webservice based in this data only, it works…
how do I make this dynamic so that it takes care of the next month data which is April data… I mean as the report is scheduled to run every month… the next month data will come… how do i make my dashboard data grow automatically.
I THINK your best bet is to work the webi report so that you have a column for each month, with empty values for those months for which you don’t have data yet.
That way you won’t have to worry about adjusting for each month.
Don’t create a pivot table. Create a different variable for each month, and write the formulas so that the correct values end up in each month, and put all 12 variables in a standard horizontal table along with your “North/South” field.
