Data Federator with Spotfire
Hi Experts,
Is it possible to expose target schema of data federator as some ODBC source which further can be consumed by other reporting tools like SpotFire?
Secondly, does data federator support caching?
Thanks in advance!
Megha
megha_musale (BOB member since 2009-09-02)
Hi Megha,
The Data Federator supports both JDBC as well as ODBC drivers which can connect to the DF Target Schema.
You need to install the Data Federator Drivers to connect to the DF Target Schema.
Can you please explain what do you mean by caching in the DF?
Cheers,
Ranjul
ranjul.gupta :india: (BOB member since 2008-10-16)
[Moderator Note: Moved from General Discussion to Other Products]
