We are extracting data from success factors,but we are getting the row delimiter and column delimiter issue.We are using the default delimiters \127 and \007.BODS version is 4.2 SP06.
Other than cleaning the data from source end is there any solution for this issue? Is there a possibility to set a pipe symbol or a unique symbol as delimiter(which will not be in source data) in Success factors API or some where at adapter level so that we can extract without any issues.
Vamsi
mvkreddy15 (BOB member since 2015-05-13)
